Loose 650 Motor Mounts = Bad. Check yours now.
Old 04-28-2004, 11:52 PM
CrekRunner's Avatar
Default Loose 650 Motor Mounts = Bad. Check yours now.
Very good info Nyroc. I had to replace 2 bolts in the rear and tighten the one in front, last year.
Old 04-28-2004, 11:54 PM
KISSSOFDEATH's Avatar
Just got off the phone with ya nyroc. I will check mine out tomorrow.
Old 05-01-2004, 08:14 PM
Pray4a650's Avatar
Mine where loose too! Thanks Nyroc, you saved me a lot of future grief.
Old 05-01-2004, 08:31 PM
I never did check mine. I closed on refinancing the house that next day. I will get to it one day though.
  #15
Old 05-02-2004, 01:43 AM
kawiyowee's Avatar
Alcohol? Check
Tobacco? Check
Firearms? Check
Motor mounts? Check
Ok, let's go.
  #16
Old 05-06-2004, 10:31 PM
ericruby's Avatar
rider from owego, ny the bearing at the bottom of your steering post is probaly worn, I had the same problem with mine, the bearing was about 95 dollars
  #17
Old 05-06-2004, 10:36 PM
Kawi650's Avatar
Originally posted by: kawiyowee
Alcohol? Check
Tobacco? Check
Firearms? Check
Motor mounts? Check
Ok, let's go.
Don't forget to check the gas and drive safe[img]i/expressions/face-icon-small-wink.gif[/img] haven't checked mine yet but I will.
  #18
Old 05-08-2004, 09:39 PM
jhmach's Avatar
My main rear bolt was loose! and rr two small one were plum gone! not there,,,, thanks again JHMACH
  #19
Old 05-09-2004, 12:50 AM
kodiac1's Avatar
Holy cow!mine WAS loose.The question I have is are you supposed to center it as best you can or just tighten it?Is there rubber in it or is mine just kinda wallered out???Was everyone elses or did anyone elses have pretty good movement in it???
02 650 camo
  #20
Old 05-09-2004, 02:13 AM
bbertram's Avatar
Sounds like alot of them are loose, I will check my V tomorrow. I will also check my P when I get back down south, I'm sure they are loose.
Quick Reply: Loose 650 Motor Mounts = Bad. Check yours now.
