Can't start p650 unless brake on problem>
Sup all. I am having a prob with my P650 and hope someone can shed some light on the subject. As you know if the bike is in neautral, you hit the green button to start it. When its in gear you have to hold the brake on to start it. Well you have to hold the brake in to start mine even if its in neutral. It used to be fine now it ins't. Any ideas?
I dont own one but judging from previos posts probaly has something to with your neutral start switch
Uh? Park? Do you mean neutral?
I think your neutral start relay is bad. The brake start relay works even in neutral. the neutral start relay only works in neutral.
Seemy post in this topic. |
Yeah I meant neutral
Problem fixed. I took the relay off and cleaned it with some electric parts cleaner and then beat on it with a screwdriver handle. Works now! Thanks, must have just been a stuck relay
| All times are GMT -5. The time now is 05:50 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
