instrument pannel gone crazy
Old May 16, 2004 | 09:04 PM
digitalsniper's Avatar
Default instrument pannel gone crazy
Today took the bike out for a few hours, brought it home and cleaned it up. Decided to take it for a spin around the yard and after about 5 minutes my instrument pannel started flashing, the reverse light was flashing and it was hesitating if i gave it any gas above a fast idle.
It ran great all day, and when i cleaned it, i didnt even take the seat off to clean under it so i discount any water getting in the electrical since i mainly washed the undercarriage.
Any clue?
2002 prairie 650
27" swamp pros
DG G3 module
2" lift
Thanks
Old May 16, 2004 | 09:22 PM
92LT's Avatar
I would let it dry out thoroughly before taking it apart. Maybe it was just a fluke and water go into a connection.
Old May 16, 2004 | 09:46 PM
Its sitting with the seat off in the barn ATM. Ill take a look at it tommorow night after work. I thought it might be the DG module, but the LED was flashing at idle. (couldnt rev the engine up to see if the flash sped up.).
Which speaking of G3 module, I really dont see ANY performance gains with that thing. They said i wouldnt see as much since its a 02 model but they said there would be some. wonder if its screwed up...
Old May 16, 2004 | 10:16 PM
Haynes1111's Avatar
Maybe your belt senor was tripped and needs resetting?
Old May 17, 2004 | 10:08 AM
Is that what happens when the belt sensor is tripped? Nothing subtle about that if thats the case.
Old May 17, 2004 | 10:39 AM
DEL700's Avatar
[img]i/expressions/face-icon-small-wink.gif[/img] Your belt has tripped and you are now in the limp mode. Mine did the same thing after I washed it. This was on the 650 about a year ago, no trouble since I reset it.
02 P650
DG holeshot
snorkle
Black spring
04 P700
snorkle
Dayna CDI
26" midlites and C-series
Old May 17, 2004 | 11:31 AM
Since i smoked the belt twice a month ago, i should prob. just go ahead and replace the belt im guessing since its tripped.
Will it auto reset after i replace the belt?
Thanks for the info.
Old May 17, 2004 | 06:05 PM
newbeatle's Avatar
You will need to flip the on/ off switch on the inside of the CVT cover...
Old May 17, 2004 | 07:08 PM
kawakasi's Avatar
Same thing happened to me the other day......[limp mode and the dash going crazy]
the belt trip thingy was tripped only half way
I"ve had the belt thingy trip before....all the way....but never half way
Old May 22, 2004 | 05:35 PM
mainman's Avatar
Hi there mate , i have problems with my dash flashing and blowing main fuse , have you any answers yet , have you solved your problem .
