Please respond! P700 or Brute750.
Old Mar 18, 2005 | 09:25 PM
want2Bmuddy's Avatar
Default Please respond! P700 or Brute750.
I have owned a couple atvs and I am wanting to buy a new one. I rode my first Kawa P700 today and fell in luv with the power and ride. I am also interested in the brute force 750.
What is the pros and cons of each machine?
I read that the transmissions are different btwn these 2 machines, is one better than the other?
How do you rate these machines?
I want a utility machine that is fun to ride. If you were in the market today, which atv would you choose?
Any and all info you can give will be appreciated as well as problems. Ive done a seach and would still like to here from you! Thanks
Old Mar 18, 2005 | 09:31 PM
walker360's Avatar
it depends on how you ride
trail riding go with the prairie
farming go with the prairie
mudding go with the brute
foolin around go with the brute
i personally would go with the praire
i just love them prairies
hope i was some help
Old Mar 18, 2005 | 11:34 PM
mudblaster's Avatar
go with the p700 its got the best warrenty 3 years the brute only has 6 months.
also i have had an irs quad and found that going up big hills its unpredictable and tend to pull the front tires.
where as to sra wont pop up like that .
the irs will ride alot smoother then the sra.
but i dont think it will be as good on the trails as the 700p.
plus i like the body style on the 700p better.
i think the warrenty should tell you what is a better quad.
or the brute would have 3 years also.
Old Mar 19, 2005 | 02:06 AM
grizzkiller's Avatar
all of the kawi's have 6 month warranties around here. at least i think so, i havnt heard of any kawi comin with a 3yr warranty. not knockin ya mudblaster, just i havnt seen it, i could be wrong. as for the to big kawis. i have a brute 750, my brother has a prairie 650. i cant say which one is better. they are similar yet different. both are very fast. we have drag raced and the brute is faster but only by a little i believe. both do mud extremly well, edge to the brute because of ground clearence, but this is only noticable in really extreme mud. high speed trail riding goes to the prairie, sra means better stability at higher cornering speeds.technical trails and comfort goes to the brute due to irs.the prairie has less bugs due to being out now for like 3yrs. my brute has run well, so i think they are both great kawasaki products. so they both do mud well, they wheelie easy, they are fast. so if going fast on the trails is your thing then the prairie is it, if conquering the mud and comfort then the brute is the one. what ever you choose will be a great machine. as for looks they are totally different, the brute looks as if you are flexing your muscles, the prairie looks like you are going fast even when your not. good luck with whatever you choose.
Old Mar 19, 2005 | 03:03 AM
kawiyowee's Avatar
One of the best riders I know uses his BF750 mostly for gully crawls (boulders, mud, steep v-shaped gullies). The 750 is better for that. The 700 is best for trails or looking down into gullys. It will gully crawl too if you want it to. I could have had either one a couple of months ago, chose the P700. Get what feels best to you before you buy.....good luck.
Old Mar 19, 2005 | 09:23 AM
handycap's Avatar
P700!
Old Mar 19, 2005 | 11:14 AM
MALAHATMAGUIVER's Avatar
Caddy or Corvette? This is the question! SRA vs. IRS. You can't loose either way.
I love the way my P650 rockets around corners.(sprint car style)The front springs on the prarie need some help.At times I find my 650 to be rough riding,thats when I wonder if an IRS would be "nice".Two corners later I have forgotten "nice"and I'm thinking"nasty"again.
Both are an excellent choice,don't forget the BF 650 as well....great line up!!!
want2Bmuddy,good luck on your choice,lucky for you it's a win-win situation.
The P700 in Canada has a three year warranty.
Old Mar 19, 2005 | 02:04 PM
Puttnutt24's Avatar
Ok, lets twist the question a bit.. P700 compared to the Brute SRA 650 ?
Old Mar 19, 2005 | 02:40 PM
Jeffro31's Avatar
I have been there , I have owned several prairies before getting the BF750i , the prairies will power slide and do donuts better the the brute rides better and does better on technicial riding, I can easily ride by BF as fast as anyone does on a prairie , I used to think different till I bought the 750.You can ride faster and longer the more confortable you are and the BF feels better after a long ride.
Old Mar 21, 2005 | 12:09 AM
CamoKVF700's Avatar
You should be careful saying you could ride the 750 as fast as anyone on a P700. They might take you up on that and spank ya. Maybe in your group of buddies, but not mine.
