Bayou Question
Old Jan 14, 2008 | 01:30 PM
SammyK's Avatar
Default Bayou Question
I've got a 1995 Bayou 300 4x4. The speedometer cable is damaged back where it attaches to the final drive in the rear.
I don't really care if the speedo works or not, and was wondering if there is a cap you can put on the hole where the cable goes into the final drive.
I believe the speedometer was optional on this quad, so I figure there must have been such a part for those quads not equipped with a speedometer.
Does anyone have any experience with this? Any suggestions will be greatly appreciated.
Old Jan 14, 2008 | 01:45 PM
JustRandy's Avatar
You might be able to get a piece of rubber tubing and screw it into the hole and then screw a bolt into the tubing.
For that matter, you could cut the end off the cable and put it back in the hole.
Old Jan 14, 2008 | 01:56 PM
SammyK's Avatar
Thanks for the fast reply!
These are both good ideas. All I really want to do is keep water from getting into the final drive. I was thinking there might be some kind of factory part, but maybe I'm just over-thinking it, too. :-) I'll see what I can come up with when I get home.
Old Jan 14, 2008 | 02:07 PM
JustRandy's Avatar
Your guess is as good as mine on the factory part thing. I'm with you though, just need a way to keep dirt n water out.
Old Jan 14, 2008 | 07:29 PM
Force's Avatar
I have a 2003 bayou and installed a speedo and there was a threaded plug in there where the cable goes in.Would be able to get one from dealer.
1ArmBandit
55
Oct 14, 2015 09:03 PM
bigred20653
Oct 2, 2015 10:05 AM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
rcappie4
Sep 9, 2015 07:04 PM
