a lil help anyone
i just got a kfx 700 it has a full dual hmf exhaust and it runs great but when i first start it and i give it a lil gas 2 warm it up it wants 2 die but if i give it full gass its ok , whats your thoughts on that? and anotherthing when im ridin it, its allgood untill i let off the gass and it backfires a lil any ideas why thats happen?
Sounds lean. Was it rejetted for the aftermarket exhaust?
Try using a little of the choke lever to richen it up and see if the problem is still there. If the backfire stops, you'll need to go to a larger main jet.
Budman is right.......poping on de-cel is an indication that it is lean and the jets are probably wrong. If the person who had it before you did not re-jet the carbs then you need to do it. Any time you add an exhaust...more air out.....you need to rejet...more fuel in. Should be a simple fix.
thanks for your guys help !!!!!the guy that had it before me never changed the jetts !!!!so i got the right ones now im puttin them in this weekend i hope it takes care of the problem thanks again!!!!
