dynojets
Old Sep 4, 2008 | 03:47 PM
muddie's Avatar
Default dynojets
07 650i BF had a HMFslip on put on then a performance cdi under seat with atv mod. then i put a dynojet kit then it all went down hill..it sputters between 8 to 15 mph if i open the throttle it clears up,main jet are 136 and 140 (had a local shop do kit) and the washer set on 5,what should i do???<span class="FTHighlightFont"></span ft>
Old Sep 5, 2008 | 02:54 AM
FASTFATBOY's Avatar
Default dynojets
Trash the dynojet kit or atleast pull it out of the bike. Run the stock needles with 1 shim under each needle. Use #4 brass washers from Home Depot or Lowes to shim the needles. The washers fit perfect and are the perfect thickness. Use keinin - stock mains. Take the rear main and put in the front carb and go 1 size larger for the rear carb. Most people don't like to hear that the dynojet kit they just spent money on isn't the way to go but it's the truth. If you will go with the stock needles shimmed and 1 size larger main in both carbs I will just about guarentee you you'll be screaming down the road instead of popping and studdering.
Old Sep 5, 2008 | 08:09 AM
muddie's Avatar
Default dynojets
hmf says for my bike its 165for the front and rear (keinin of course)so what size should i get?i called local dealer shop and they said both front and rear are 155.. and hey! thanks for all the good tips you have helped me out very much!!hope to hear back soon P.S yes dynojets are JUNK!!
Old Sep 5, 2008 | 12:43 PM
FASTFATBOY's Avatar
Default dynojets
If HMF recommends 165 then go ahead and go with what they recommend. I'm sure they've done the dyno testing and know the best combination for the majority of bikes out there. Not a problem I hope you get it all lined out.
Old Sep 5, 2008 | 12:53 PM
muddie's Avatar
Default dynojets
thanks for all your help..!!!!ride hard and have fun!
Old Sep 18, 2008 | 06:38 PM
muddie's Avatar
Default dynojets
on my 07 brute force they say 155 are in both carbs stock ,so what size should i go with?i have the stock needles in,and should i change the spring back to stock that covers the needles?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Sep 19, 2008 | 02:13 AM
FASTFATBOY's Avatar
Default dynojets
160 mains and put the stock springs back in
Old Sep 19, 2008 | 06:00 PM
muddie's Avatar
Default dynojets
will give it a shot...thanks...
chop
14
Apr 26, 2001 03:02 PM
DSAPP
Jan 31, 2001 08:34 PM
nightlife7810
Oct 17, 2000 04:36 PM
CG400exMaster
Sep 25, 2000 12:17 PM
RVonSand
Dec 2, 1999 11:41 PM
