02 P650 Winch mounting Q's
I just installed an Xtreme winch on my 02 P650. Does anyone have any slick Ideas on a mounting position for the handlebar switch? The Stock Levers & Controls take up alot of space on the Left bar. I ended up doing a vertical mount and It will work but its not as clean as I'd like. Any Ideas? ALSO where would be the best location to mount the contactor.... I'm planing on mounting it under the seat but the one on my 05 Cat is right next to the winch exposed.
There is not much space on the left side handlebar area but my Warn (2500) winch's switch barely fit on there.
I mounted the contactor in the very rear of the ATV under and tail light area on the tube frame. I will try taking some photos and show you. |
I mounted mine in the box under the seat.
Well.... I did get the contactor mounted..... Switch Mounted..... And wouldn't you know it.... The contactor was bad right out of the box.... It will reel out my cable...But not reel it back in.... I am getting a squeal from the contactor when you push the button to reel the cable in.... Everything is wired correctly... So I had to cheat and use a battery directly to my Winch motor to reel the cable in....
| All times are GMT -5. The time now is 12:07 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
