1994 Kawasaki Mojave 250 Engine Floods I Think
if its oil the plug will be covered in it, and spell like oil. dude you need new rings if its smokeing like that! compression is suffering so it will be harder to start and keep running. if it runs better the plug will continue to get oil fouled and the smokeing will get worce. change the rings before you do some serious dammage and scare the jug bad or skrew up the wrist pin-piston-arm.
ok so it shouldnt smoke on start up then and the pulg has never been fouled nor covered in oil also my compression isnt poor tho i dont know what it is but its not bad but it only smokes for maybe 3 minutes on cald start up and than it stops and if i tac it out it will burn only a little bit just a small puff also if i sits for maybe a week or so it will smoke
sorry i got you mixxed up with another dude with an oil fouled plug. but still it should not smoke at all. the propper weight oil will help, for a while anyways. but its a good idea to fix your mechine before it costs you more $'s. a guy ran his ACT around for months while it was burning oil lightly, kept getting a little worce until finally the rings just crumbled and pieces got cought everywhere in the tranny case [img]i/expressions/face-icon-small-sad.gif[/img]
but like i said, part choke, no throttle tapping, and mabe replace needle &seat.
1000gade
07-16-2015 10:48 AM
Mojave250A
07-11-2015 10:38 AM
