Brute 750fi won't start
Took the gas tank out of my 10 Brute to make some bigger holes in the case that encloses the tank. Case had at least 10 lb. of mud in it that is impossible to remove, so bigger holes should make mud removal easier. After putting everything back together, engine starts and runs for about 2 seconds, then quits and won't restart. Either fuel pump is not working or a sensor is shutting things down. I am positive no lines are kinked and everything is reconnected as it was. Any thoughts ? Dealer is closed today but will talk to them tomorrow.
Problem solved. The last relay under the seat is called a tip over sensor. I of course, reinstalled it upside down. Would be a great trick to play on your buddy who has a 750fi,,,,, I didn't say that.
| All times are GMT -5. The time now is 04:29 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
