Kawasaki prairie 360 cuts off
I just bought a used Kawasaki prairie 360 that had just had a brand new carb installed. It cranks up an runs fine for about a minute then shuts off like the key was turned off and won't crank again for a couple if hours. It will run wide open again for about a minute and then shut off again. Any suggestions where to start? I took the tank off, cleaned it out and installed a new petcock. The old one was very corroded and the filters were gone.
Did you ever fix this????
Actually have the exact same issue and was wondering if you ever fix this if so can you please either text me or email me 252-314-4140 I just took the carburetor out and cleaned it even took each one of the screws out and clean there too there was a little bit of water in there but not much even pulled the needle out and cleaned it as well the only thing I think it could be is the line or the petcock itself although it is getting gas through there
Scooter's Shop
23
10-22-2015 07:04 PM
