Bayou 250 just clicks when I try to start it
I have an 03 Bayou 250 that just clicks when I try to start it. The battery is good and the connections at the starter relay, battery and starter are tight. I cannot get it to start with the pull starter either. Any idea what is wrong?
bump
"I cannot get it to start with the pull starter either."
This throws your question too wide, if you pull and the engine spins but won't start, that is one thing but pull and the engine won't turn over, that is quite another. To test the electric start I use a test lamp. Switch on, connect one wire to earth, t'other to the starter lead post on solenoid. Press start button, if the lamp lights but the motor doesn't turn, (assuming the engine isn't seized) you need to strip the starter, probably needs new brushes. If the lamp doesn't light but that solenoid clicks, you need a new solenoid. |
Originally Posted by merryman
(Post 3358006)
An update: I can start the bike no problem with the pull starter. I tried bridging the two terminals on the solenoid and the green neutral light goes off and I get nothing while holding the start button.
The starter may have an internal short, but it is most likely that either that battery isn't "good" or all connections are not "tight". Try jump leads to the battery and see if that makes any difference.
(Post 3358281)
Measure the resistance with a meter between negative term on the battery and the negative starter terminal - should be a few ohms - less than 10. If it's open, check the ground strap from the engine to the chassis and from the battery neg to the frame.
The click elimnates the relays and the solenoid I think. Good luck |
Originally Posted by lciummo
(Post 3358335)
The click elimnates the relays and the solenoid I think. Good luck I have replaced the starter relay and starter, made sure the fuse in the relay was good, cleaned the connections at the battery and ensured that the connections for the ground strap on the engine block and power wire to the starter are tight. I am still getting the exact same problem. Clicking when pushing the starter button and when I go to bridge the bolts on the relay I get the neutral light going out and nothing happening. |
Have someone push the starter button and take a reading with your meter right at the starter motor. If the volts are too low to turn it over, then trace backwards to the relay, and so forth.
