Kawasaki KLF Ignition prtoblem
Hello to all, I have a KLF 220 of about 1990 vintage, I recently stripped out the starter slip clutch to replace the rollers, on rebuilding it I find that while it cranks ok it won't start ! So I remove the spark plug and try for a spark !! Whilst holding the starter button in there are no sparks but as I release the button there is a spark at the plug !! Press again, no sparks, release, spark.etc.
I have tested the coil in the engine (signal coil to CDI) and the HT coil both of which were within the range specified in the manual, As I have another spare machine I changed both of these coils to no avail.
I'm lost from this point on !! Has anyone come across this issue before and if so, what was the cause?
Brandon Johnson
04-01-2018 09:19 PM
