black spring 02 p650
Old Mar 26, 2003 | 11:37 AM
littlecanuck74's Avatar
Default black spring 02 p650
want to start to modify my p650 with the black spring
can i just do the sping on its own or do i have to do another modification along with it
either with another part or adjustments
Old Mar 26, 2003 | 12:03 PM
RebelDS's Avatar
Some people may want to put in a red drive spring, but I didn't want one. But the main thing you need to do when you change your spring is to check your belt deflection. Odds are that your belt is on the loose side from the factory. If you get your belt on the tight side, it will cause your belt to last a lot longer, in addition to the benefits of a black spring.
Old Mar 26, 2003 | 12:28 PM
trx450's Avatar
I you ride a lot of tight/technical trails, you probably do NOT want the red(drive clutch spring), stick with the black(driven clutch) spring. With the red spring, the throttle becomes similar to an on/off switch. Not so good for tight, slow work.
Old Mar 26, 2003 | 01:46 PM
i drive all sorts of trails tight ,wide open roads ,power lines ,but i also plow my drive way is the
black spring best for me
Old Mar 26, 2003 | 11:09 PM
Tonerpuke's Avatar
I think just the black spring and tightening up the belt is the best solution for most people, Make sure you put the belt back on oriented the same way it was on from the factory. It is possible to put the belt on backwards and I have heard reports of belt slippage if this occurs. Just look at the writing on the belt when you remove it and put it back on the same way. The writing on my belt looking straight at the clutch had the writing facing me as you would read it.
Old Mar 26, 2003 | 11:14 PM
Hardwood's Avatar
I installed just the black spring and I ride in much of the same condistions that you do and it works great just by it self. You do not need any other mods. for the black spring and like said before the red spring makes it engauge at a higher RPM and makes it not as trailable to most people.
Old Mar 26, 2003 | 11:40 PM
Lurch77's Avatar
Also, the arrows on the belt help too. [img]i/expressions/face-icon-small-wink.gif[/img]
Yes, for most people, the black secondary spring and re-shimming the clutch (if belt is loose) is all that needs to be done. This greatly increase belt and clutch life. A properly adjusted belt and the black spring will also show a performance increase over a sloppy belt. I am not talking night and day performance, but the belt does grab much better when set up right.
Old Mar 27, 2003 | 07:55 AM
trx450's Avatar
As for belt orientation, I just remember to put it back on so that you can read the "KAW" logo, while hunkered down on the RH side of the bike, working on it
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
