50cc atv hard to start
I have 50cc quad , It has been very temperamental from day one. It takes alot of cranking over to get it running. I have good spark . Today I pulled the spark plug and shot a seringe of gas in the cylinder. Tried to start it and same senario. It will eventually crank over after 8-10 minutes. I usually have to put a charger on it after so many cranks . Not sure what to check next. Any help would be appreciated . Happy Holidays !
Merry Christmas! it sounds like your valves need to be adjusted for a hard starting/cranking problem. surely it's getting plenty of fuel. i'd look at the valve clearances and check compression with a gauge, not your thumb.
So I checked the valve clearances and still same issues. When I pulled the exhaust valve cover (cap) , there was a considerable amount of oil and gas mixture inside. Is that normal or ring problems ?
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
