Scrambler 90 tranny problem?? Or rev limiter?? Help
Old Apr 26, 2004 | 07:02 AM
AgentOrange51's Avatar
Default Scrambler 90 tranny problem?? Or rev limiter?? Help
I just bought my son a '01 scrambler 90. It seems to run great but I got on it the other day and when i went up a hill it felt like tranny was kicking out of gear then grabbing again . This was at full throttle. It does not seem to have this problem on level ground but only on inclines. Any ideas would be very helpful.
Thanks
Old Apr 26, 2004 | 07:41 PM
BradLoomis's Avatar
The belt is slipping in the transmission. Us big guys just weigh to much if you are trying to go up a hill.
Old Apr 26, 2004 | 07:43 PM
oldyeller's Avatar
Sounds like a problem in the drivetrain somewhere if it only does it under the extra load of going up hill.Is it making any noises?I'm thinking maybe your chain could be skipping on the sprockets(loose or worn out chain or worn sprockets) or perhaps the belt is slipping.Do the clutches seem to shift out ok when just running on flat ground.
Old Apr 26, 2004 | 10:51 PM
yeah it shifts out ok. The noise is like a metallic clunk. Sorry, crappy description.
Old Apr 26, 2004 | 11:26 PM
oldyeller's Avatar
The belt shouldn't slip.I'd look at the chain and sprockets and check the transmission shaft for slop,maybe worn bearings.
Old Apr 26, 2004 | 11:28 PM
ok. thanks for the help. I'll check those things out.
Old Apr 27, 2004 | 03:07 PM
BradLoomis's Avatar
Most of the time the belt will slip way before the chain can skip a tooth. What usually happens to create the metallic noise, is that as the belt slips it decreases the tension on the chain and then the belt will grab and increase the tension and spring it. It is alot like actuating a manual clutch very rapidly in and out and it is more pronounced because you are at full throttle, heavier than your kid and going up a hill.
When I noticed this with my sons bikes, I asked him if he felt it and he said no. Then after a couple of races he said it felt like the chain was skipping on the startingline. So I pulled off the side cover and cleaned the belt dust out and changed the belt. Problem went away for about four more races. So now I just maintain it after every race. Since yours is '01 it is probably just in need of a servicing.
If you need anyother help I live across the river in Woodland. PM me I can I can give you my #s. Hope this helps.
skinnyr6
Aug 25, 2023 02:18 AM
Ramman1
Jun 16, 2016 09:07 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 13, 2015 05:11 PM
Chocobamofo
Jul 10, 2015 07:46 PM
