Kill switch TRX 90
Has anyone installed a kill switch on a trx90? I need to install one to be in compliance with the track rules. Do I need a normaly open or closed switch? Also which wires do you hook it up to?
Kill switch TRX 90
Normally open. I bought one from Dennis Kirk. A generic parts ulimited brand. I hooked it up between the off switch on left bar and the keyed ingnition. There is only a few wires there. Just cut in and hook it up by twisting wires together. Try and start it. If it's wrong flip the 2 wires. After its right do the conections right. I cut the connectors off and soldered and heat shrinked it. You dont have to do it that way. If you need any other help with the TRX 90 e-mail me. jim@mti-mn.com
