LT 80 won't start good compression
My son's LT80 has 150 lbs compression and very little to no spark at times, both coils has good resistance can someone help? Its been about 7 months now. [img]i/expressions/face-icon-small-disgusted.gif[/img] |
Sometimes crud build up on the stator. Pull the flywheel and sand/clean the stator and flywheel.
Thanks, I'll try that.
I assume you checked the coil resistance while it was off the bike, make sure the coil has a good ground when it's mounting.
Good luck |
| All times are GMT -5. The time now is 06:10 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
