eton blowing fuses
hey guys any ideas on where to start with my sons eton 70 blowing fuses with the electric start it works fine with the kicker but just fryes the fuse at the battery with the electric start
also who makes a good kicker for this bike |
eton blowing fuses
First i heard of the fuse blowing but you might try the ign. switch
eton blowing fuses
thanks i will try that
eton blowing fuses
If its blowing fuses, it means theres a short between the fuse and the load, or the load is bad. Disconnect the wire at the starter, and then see if the fuse still blows. If it does...definent wire problem...wire pinched, or rubbed bare and is touching the frame. If it doesnt blow, then have the starter tested, the brushes could be worn .
