kazuma wheel spacers
Old Oct 13, 2005 | 11:46 PM
Topdollr's Avatar
Default kazuma wheel spacers
anyone know what wheel spacers will fit the kazuma 50? Front and rear
Old Oct 18, 2005 | 08:22 PM
flexikid's Avatar
I guy on ebay sells them.
Old Oct 18, 2005 | 09:44 PM
Topdollr's Avatar
do you have a name or maybe an item number?
Old Oct 19, 2005 | 11:59 AM
3boysmom's Avatar
On ebay the guy i found is Speedtrap4
he has them forthe 50- 110 - 150
item # for 110 and 150 is 4581659176 (this end in 2 days though)
What i would like to know is has anyone used these yet.. IF so do they work or are thye ones (bigger) raceway sells better ( more expensive). have not been able to find many venders out there. maybe i am looking in wrong places.
Old Oct 19, 2005 | 01:00 PM
Propertymaint's Avatar
Denniskirk.com has different types of wheel spacers available. Even though most of them are CNC machined the prices are in my opinion expensive. The full plate spacers are most likely the best but I tried the thread on studd extenders on my two Kazuma KMZ150's. They appear to be holding up quite well but I do mostly trail riding. From what I have read, the stud extenders are O.K. for normal riding. If the atv sees considerable jumps and hard riding then the full plate type spacer is prefered to prevent a bent axel. I used the 1 1/2 inch spacers for both the front and the rear -total of 3 inch width increase - huge difference in the handling of the atv. The turning radius suffers a little but not enough for concern. The extra width on the front end acually exerts more leverage on the front suspension and softens it a little. I believe the studs are 10mm. If you decide to go this route check the wheel stud for proper size and thread.
Good luck
Old Oct 19, 2005 | 01:47 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I prefer the solid aluminum type like Propertymaint suggested.
Old Oct 19, 2005 | 08:19 PM
flexikid's Avatar
I have the 2 1/2 studs on the rear and it really helps a lot. I'm not sure I want to use them on the front becasue of the extra stress it would put on the front end.
Old Oct 19, 2005 | 09:27 PM
Topdollr's Avatar
I am just looking to widen my sons 50. So stress isnt an issue either is jumping or rough trails. What kind of money did you all spend on your spacers? I think I will go with the stud extenders.
Old Oct 20, 2005 | 07:50 AM
$50 per end
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
