Beware of SMC CRS 200
Hello ATV lovers I have bought SMC (Standard Motor Company) quad 200ccm
After couple of miles the wheels fel off the quad????
After plenty of screw glue the same thing happand after couple of miles.
I replaced bolts with bolts from tools shop and I fix the problem
BUT then
The engine is installed to the rear so the whole weight is to the rear.
Witch cause the front end to go wherever it wants????
This is 200ccm quad with top speed of 80km/h about 65miles
with only drum brakes?????? that are overheated fast.
The rear axle has broken down tree times, gearbox two times and shoks
have puled apart the frame four times
If someone have some exp. with SMC please say
BUT then
BUT then
BUT then
No it didnt drop of the truck every one of the SMC 200 CRS is having that
problems The owner of the shop told me so.
Also SMC ARES 250 have some problem with shifting into the neutral gear.
I will send you ditails soon also about any ATV that I got my hands on
RIDE SAFE !!!!
RIDE SAFE !!!!
Customer Service #1
05-15-2020 08:46 AM
