how can i make my 06 trx90 faster
How can i make my 2006 trx 90 faster with out adding anything on to the engine? (like exhaust,revlimiter,airfilter ect.)
I just bought it and i dont want to spend any more money till later.
I heard about cuttin apink wire on the engine but im not sure how to go about doing that.
As a suggestion, give Rob at call. I hear he makes a mean TRX-90 racing machine. His details are:
http://www.robbsracingengines.com/TRX90PAGE
As a suggestion, do ask him about cutting the pink wire on the factory CDI. If anyone would know, he definately would.
Hope this helps...
Hope this helps...
locate the main wiring harness coming out of the engine, simply snip the pink wire, it is a 4th gear speed resrtictor. get a free flowing air cleaner, k&n/no-toil/etc... check your jetting.
depending on what you ride re-gear. real in-expensive hop-up is to run a thinner head-gasket for more compression.
Thanks for the help and I will try it! I got a big gun exhaust system and a k&n air filter for it so will it go even faster if I cut the pink wire or will it still top out at the same speed? And would a Rev limiter make it go faster to or is that the same as cutting the wire? Thanks!
2005 trx 90
MikeyBoyesq
08-10-2015 11:11 AM
