Kids Quad Speed Limiters
Help!
Recently I purchased two 70 series Hensin Tierra's for my two boys. I need to slow the machines down. They have a throttle screw, which would be fine if they road around in circles on a perfectly flat track, but they don't, and the boys know how to operate a screw driver.
I need to find another method to control the speed. Does anyone have information about CVI speed limiters, exhaust restrictors, or other idea to achieve this.
The machines are in lockdown until we resolve this issue.
Thanks!
Thanks!
I agree with setting the rules and making them obey or no riding. But some of the mini quads are just geared to high. If you limit the throttle too much they just can't make enough RPM's to get going. What you probable want to do is change the sprockets. Go with a smaller sprocket in the front and or a larger sprocket in the back. This will lower the top speed and give you much better low speed torque. This will let you back out the throttle limiter some and let the engine run higher RPM's, more in its power band, rather than lug around just above idle.
Thanks for all of the responses. You have identified the root of the problem, which has everything to do with performance, not parenting. Gearheads are gearheads from birth, and we've all broken, or should I say bent the rules a bit, regardless of what you're father told you when you were a kid.
There are many things that can be done with the screw, however I only included that statement in jest . I/C engines do not have a constant torque curve, which is why setting the screw in one position doesn't work.
What I really want is a speed limiter, but, after speaking with several vendors, all of whom are interested in increasing speed, have not found what I'm looking for. I haven't been able to get into the guts of the machine yet, but plan to change the sprockets to help mitigate the low end problem. Ultimately, I will probably end up building a control loop to achieve what I want, if I cannot find COTS items.
Here are some of the COTS items I'm looking for:
1. A speedometer with a 0 - 25 mph scale with an output relay that is activated at a set speed.
2. a 12V DC rev limiter that will interface with the existing CDI. The CDI is a 12V system, not a grouding system.
Regarding the CDI box on a predator 50; I haven't been able to find any info on that. I contacted the parts department of local Polaris dealer and they had never heard of a CDI box with two settings. Any additional information regarding that item is appreciated.
Thanks again
Thanks again
