Kazuma 50cc Won't Start
Old Dec 15, 2006 | 09:24 AM
  #31
asiachef's Avatar
Default Kazuma 50cc Won't Start
its an off brand but its similar to a Yamaha Raptor, but the parts are interchangeable with Honda here are the specs
Engine 107cc: 4 Stroke, Single Cylinder, Air Cooled
Transmission: Fully Auto no reverse
Suspension: Dual A-arm
Ignition: 12V,C.D.I.
Starting: Electric
Max Power(Kw/rpm): 4.0 Kw(5.4Hp) / 7500
Max Power(Nm/rpm): 5.6 Nm / 6000 Rpm
Net Weight : 160 LBS
Weight Limit : 250 LBS
L x W x H : 52" x 33" x 38"
Seat Height : 28"
Wheel Base : 33"
Tires : 16x7-8 7" rim - 16" tall tire
Brake : F Disc Brake Hand Brake
Max Speed : 35 miles/hr
Petrol Tank capacity : 1.6L (0.423 Gal)
Light : Dual Head Lights / Single Tail Light
Old Dec 15, 2006 | 05:03 PM
  #32
Guest
Guest
Posts: n/a
sounds like the starter rely or some folks call it the silonoid
pedez2000@yahoo.com email ill help you out ok
Old Dec 15, 2006 | 10:33 PM
  #33
godIlove2ride's Avatar
From what it sounds like you have either a Kazuma Falcon, or a Redcat FX-150. They are the same quad. I agree with the solenoid most likely causing your issue. Depending upon what it looks like you may be able to jump across the poles of it to see if it turns over then. If it does turn over by jumping across the poles, then the solenoid is your problem.
Old Dec 18, 2006 | 10:15 PM
  #34
Slick250R's Avatar
Do you think if i adjusted the valves on my sons meerkat 50, that it would solve my problem of cold starts;runs fine when warm;already cleaned carb completely.Very extended cranking when cold;have to use battery charger to get it started;battery wont do it.Starts back up and runs fine when warm.I have adjusted the carb with the 1 1/2 turns-out starting point.I also pulled off the flywheel cover to check if the flywheel key has slightly sheared and possibly offset the timing;but that's not so.Have changed the plug but dont know what the gap is supposed to be;papers never said.
Old Dec 19, 2006 | 11:13 AM
  #35
JD4020's Avatar
Slick250,
I think adjusting the valves will definately help with your problem. You will be amazed at the difference. We take care of 5 - 50's between my kids, nephews, and friends, and every time one of them has hard starting problems, a valve adjustment takes care of it. They generally need this done once or twice a year. After adjusting them, it only takes a touch of the button for it to fire, no more cranking and cranking to get them to fire.
Jon
Old Dec 19, 2006 | 01:29 PM
  #36
Guest
Guest
Posts: n/a
yes i agree try to adjust the valve.
and on the air fuel screw use the 1 1/2 out as a starting point move it a 1/4 to 1/2 turn in or out
Old Dec 19, 2006 | 02:29 PM
  #37
work2play's Avatar
I adjusted the valves on mine and it resolved my problem. both valves were to tight so they were stuck open. Now the thing starts first time without choke.
Old Jan 26, 2017 | 07:27 AM
  #38
Manie7justin's Avatar
Default Do you have the manuel
Originally Posted by ;2219015
i have a new hand book and parts book it has everything in it like when you buy a new atv 50cc kazuma or redcat same unit email me if you want it
hi could you email this to me please
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
merryman
Jun 27, 2015 03:31 AM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
dcoleman
Oct 5, 1999 01:34 AM
