Help with getting new 110 started and running
UPDATE-
Well, I finally got it started. I tinkered with the idle and mixture screws and drained the carb by taking off the bottom bolt. Started up pretty quick, and ran on idle for about 30 minutes. I will now use the "adjusting the carb" thread and get it to idle at the right speed. Also I wnet ahead and put a new plug in, the old factory one already looked pretty bad. Thanks for all the help.
My only concern now is after it had run for about five minutes, I began to see a bit of smoke drifting from the engine (not the exhaust). I did drip quite a bit of gas on the engine draining the carb, and it may have just still been breaking in. Anybody have any thoughts on this smoke?
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
