Sportsman 90 Oil Pump
Continuing saga. The cable, throttle cable, that runs the oil pump does not seem to be engaging at all. As I had mentioned earlier. THe machine kick starts and will come up to idle and yesterday witht he air cover off and the vent cover off I was unable to get the cable to move at all. Should it engage as the engine continues to idle or just under more throttle?
After about 5-10 minutes the engine just stops and it will not start. Is there a safety happening here because oil is not getting in?
I am going to try the oil bleed valve tonight after I get the other side of the cover off. Dirt bikes are so much easier to work on!!!
Any thoughts on the lack of oil causing the engine to shut down?
cody500ho
14
08-14-2015 05:03 PM
house1
08-09-2015 10:49 PM
