o4 eton 50cc rev limiter wire cut the green?>
If you pull out the cdi box take a look at the side of the cdi..You will see the green wire that comes out and goes right back inside the box..It doesn't come from anywhere else or go anywhere else its just a little loop on the side of the box....It is NOT a part of the harness that plugs into the box...I have pics but can't post them on this site.
Just cut the wire and it allows the engine to rev higher...Take off the nose cone and look in to the side of the gas tank on the right hand side as you face the atv.The cdi box is hanging in a rubber holder.You can slide it out and then just snip the wire and tape the ends so they can't touch....Make sure you don't unplug the wiring harness when you are pulling on the cdi box or the engine won't start afterwards.(don't ask me how I know[img]i/expressions/face-icon-small-wink.gif[/img]
house1
08-09-2015 10:49 PM
