after removing two weights it studders
Old Jan 29, 2008 | 11:55 PM
hotblooded's Avatar
Default after removing two weights it studders
Sounds good, now it is time to hit the pilows. we will chat more at a later date. Thanks for the advice.
Old Jan 29, 2008 | 11:57 PM
onebigzj's Avatar
good night
Old Jan 30, 2008 | 09:58 AM
LT80's Avatar
LT80 Expert
FYI: the etons can be expieremented with less rollers but for the long term, the corect weights should be installed. They are spaced slightly different than the LT80's.
The LT rollers are about 10 grams each.
Old Jan 30, 2008 | 11:49 PM
hotblooded's Avatar
I was wondering, you guys run two less weights because of spacing. The Eton, running 6 I am wondering if I could only run 3 which would give it an even space. Whats you guys thoughts
Old Jan 31, 2008 | 12:44 AM
  #15
onebigzj's Avatar
dont think its a problem. (for testing) hey lt80 what you think grand pooba
Old Jan 31, 2008 | 12:01 PM
  #16
LT80's Avatar
LT80 Expert
3 is too little weight IMO.
Old Feb 2, 2008 | 09:54 PM
  #17
hotblooded's Avatar
Thank you for the advice
Old Feb 25, 2008 | 02:48 PM
  #18
onebigzj's Avatar
well now that I had some warm weather. I put the two rollers back in and it fixed the problem. now I cant keep the front end on the ground
Old Feb 25, 2008 | 02:58 PM
  #19
YZOtis's Avatar
Lean foward [img]i/expressions/face-icon-small-smile.gif[/img] When do we get a full report on that Moored LT80? Waiting & wondering & wishing mine where Moored [img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 25, 2008 | 03:10 PM
  #20
onebigzj's Avatar
had an issue with the sec. clutch. he is working on a brand new sec clutch. and hope to have it together this weekend. for the little time I rode it I decided to take off the duel a-arm kit. dint ride well. onething is if it runs as good as is sounds I will have to put the restricker plate back in. sounds like a rm80 .will begiving a full report when done
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Robinhood
Dec 26, 2015 10:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
