Pep boys 2004 edge 250
Not sure what your bearing looks like but there is usually a bearing number on the sides of bearings. If you go to www.grainger.com and enter that bearing number you might find it.
Hope this helps.
Hope this helps.
I have it completely apart I used to be a small engine mechanic. I beat the heck out if the bearings. I bought it for $200 from a friend Runs great. But he ran it on a busted bearing and cant get all of the bearing out to put a new one in. I figure another 200 to get the carrier if I can find one.
the bearings are a pressed in fit, you need to take a torch (a propane torch should work) and heat up the bearing races before trying to remove them. after the bearing are removed then use sand paper , files or what ever to remove any damage you may have caused trying to remove the bearings. when reinstalling new bearings put them in the freezer overnight.
Sw00p
09-24-2015 02:50 PM
