Cold weather jetting kfx80
Hello, I know Im ahead of myself but I meant to do this earlier.
I live in Fargo ND, the dealer I bought the KFX80 from said they cant be run under 40 degrees. How should I jet this little bugger come this winter - we run if its a sunny day at 20 degrees, he loves playing in the snow with the little quad. Speaking to the dealer there isnt a cold weather chart or anything for jets and I dont want to burn it up come this winter when I give him more throttle opportunity. Thanks Rob |
Your dealer is goofy. :D
The stock jetting is good from cold to hot, sea level to mountains. It's jetted way fat in stock form. |
Originally Posted by LT80
(Post 3047127)
The stock jetting is good from cold to hot, sea level to mountains. It's jetted way fat in stock form. I was pretty disappointed to hear him say you cant run these less then 40F as we run as much or more in winter playing in snow with the quads. When I first got it I bumped the circlip on the needle jet down a notch (richer), pulled the carb restrictor and exhaust restrictor. The plug looks good. FWIW I run Amsoil synthetic Interceptor as it doesnt stink as much as Kawie oil and seems to flow better. I still let the quad do the injection, nothing is modified. Im about 980' sea level. So he can run the little bugger from 110F through -20F and not be concerned about re-jetting? Thats good to hear. |
The injection is the only weak point IMO. If it'd get too thick to pump it'd be a problem.
To make sure all is well, maybe pull the plug after running it in the cold and see what it looks like. I'm still betting all will be fine. :) |
