2006 Eton Viper 90r 4 stroke not going into foward
Old 03-23-2013, 07:17 PM
ndepalma5@verizon.net's Avatar
Default 2006 Eton Viper 90r 4 stroke not going into foward
My daughter eton worked fine a month ago. Just started it and put it in foward and it didnt move, acts like it is neutral, I put it in Rev and it went backwards fine. I shut it off to let it reset turned key on (engine not on put it in Rev and Neutral and foward) There is no light blinking you can hear the shifter elctronically going from Rev Neutral to foward. I let it sit then started it and it still will not engage in foward. It drives backward great. Any will will be great
Old 03-23-2013, 08:03 PM
Jaster94's Avatar
i've never messed with the electronic shifter before, but just thinking out loud, can you pull the servo off and check to see if it is actually moving and if there are any adjustments on it at the linkage area? not sure how it is exactly set up, could be something as simple as a cotter pin missing.
exmotocrosser
09-13-2019 06:12 AM
flyin-lowe
12-01-2017 03:18 AM
exmotocrosser
09-26-2015 08:18 AM
BYC
09-25-2015 02:10 PM
Quadzilla Heritage
09-25-2015 01:39 PM
Quick Reply: 2006 Eton Viper 90r 4 stroke not going into foward
