dvx 90 transmission
Old Jan 14, 2014 | 05:49 AM
musselmark's Avatar
Default dvx 90 transmission
I just bought a used 2010 DVX 90 (same as Kymco mongoose 90) an it doesn't shift into reverse easily, if you push the shifter down it doesn't engage fully and then when you rev the engine it slams into reverse. Is it simply a matter of adjusting the linkage so it goes into reverse a bit more? I have a 30 day warrantee from dealer and want to make sure it will not need transmission work. Dealer is 300km away or I would just go there. Thanks
Old Jan 14, 2014 | 01:03 PM
LT80's Avatar
LT80 Expert
1st I've heard of the Kymco w/reverse having a problem.
Sure is a long drive to the shop. With that being said, If there is a adjustment, I'd try it.
Next would be to look up a parts fiche on some dealer site on the internet. Maybe that can shed some light on whether there is a adjustment or not. Plus you can get a idea on how it works/shifts.
Wish I had more for you.
Old Jan 14, 2014 | 01:57 PM
musselmark's Avatar
I adjusted the linkage to put it further into reverse and that seems to work but I guess it is the clutch engagement speed that is causing a hard shift. I called the dealer and they said that is how they are and the 300 are worse.
Old Jan 14, 2014 | 05:07 PM
LT80's Avatar
LT80 Expert
I can agree. If it is idleing too fast it can make it act like yours is doing.
I noticed that on my Mongoose.
Old Jan 14, 2014 | 05:12 PM
musselmark's Avatar
i guess that is part of the problem , if i have the idle too low it keeps on stalling, so i have to turn it up a bit
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
shimanok2
Jan 29, 2016 07:37 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
