Taotao ATA110-B 2009
We just bought this for our daughter off someone who's kids rarely used it. Unfortunately, the mom wasn't that familiar with ATVs. She thought it was a 2 stroke and was feeding it gas/oil mix. It's actually a 4 stroke.
My husband needs to rebuild the carburetor. Any idea where we can get a rebuild kit for this? Also, are all the ATA110-B's 4 stroke? I can't find any 2 strokes online anywhere. Thanks!!!! |
The oil in the fuel will have protected the carb. Try just cleaning it out with compressed air. Unless you bust a gasket when taking it apart, you won't need a rebuild kit.
He's tried. One of the jets is so clogged. He soaked it in carb cleaner, gasoline and the air compressor isn't doing anything.
A tiny piece of copper wire inserted through the jets will clean them. You can use a single strand of a multi strand wire, or if you're careful you can use a single wire pulled from a wire brush.
Amazon11 bucks for a brand new one , prime . that's the best way to fix these Tao carbs
I bought a used 110cc Chinese atv and the carb was shot. I search on google and found this site which I think is awesome. Great detail on the parts, pictures and all the specs you need to match the part you’re looking for.
Chinese ATV parts, Chinese Dirtbike Parts, Chinese ATV parts usa, chinese atv parts canada |
Yeah, amazon $9 carb, delivered in 2 days, crazy. That's China 4 u
Originally Posted by kelleycully
(Post 3293666)
Agreed... 9 bucks 2 day Amazon delivery for brand new carb...cannot beat that.
Drain fuel tank, flush with fuel one more time, and use only high octane fuel these tiny carb jets clog easily with crappy bottom grade ethanol moisture full fuel. Easy fix. |
Almost 12 month old post. Also these generic carbs are not set up for your engine so may need tuning to get running right, it is usually easier to clean the old carb out than tune a new one.
