Lt80 carb help
#42
#44
Jack's right...hard to check because they are behind the clutch and flywheel. I'm still kinda hung up on that plug pic...it still looks wet to me...crank seal leak would have you running leaner...you can kinda maybe check by putting your hand over the carb intake (plug off), crank the motor and "feel" the tug...if strong then maybe not...if weak, then probably yes...
#45
#46
#48
#50
