Eton viper mini 50 no power
Old 02-12-2018, 01:50 PM
Nick Suits's Avatar
Default Eton viper mini 50 no power
Long story short battery had died on my sons quad. Went to jump start it with car battery car was off. After some time of it not starting (believe it was to cold) now I get 0 sign of power. Turn the key and no oil light no horn no brake lights. Fuse on battery looks fine. Is there any more fuses or places to check? Not sure where to go from here would love to get it back in the yard for him.
Old 02-12-2018, 02:57 PM
Start at the battery and check connections and voltage.Use a meter or test light. Fuses also may look good,but they can still be shorted out.
Old 02-12-2018, 03:02 PM
Nick Suits's Avatar
Plan to get new fuse and new meter tomarrow can’t seem to find where I’ve placed mine
Old 02-13-2018, 03:59 PM
Nick Suits's Avatar
My suspicions lie in the starter relay I have power going in with solid red wire I have test light power with green and yellow wire when brakes are applied and nothing from red and white or black and white (when I test black and light you can feel and hear a click in the relay ) so my question is bad starter relay? Below is my idea of what wires go we’re would be wrong also
solid red. Power in
green and yellow brakes?
Black and white goes to Cdi box I think and also the wire to the brake and starter button
red and white goes to starter I think
Old 02-13-2018, 05:37 PM
I'd test 12 volts to the starter to make sure it's ok first. If the starter is ok,but the relay just clicks,it's probably burnt out. Polaris has a similar setup on it's youth model 50 and 90s. Plenty of cheap relays on amazon or ebay for Eton machines.You should be able to match yours up from this list.https://www.ebay.com/sch/i.html?_odk...relay&_sacat=0
badboi24gt
12
01-09-2019 08:01 PM
AtvGuy4life
01-16-2018 10:31 AM
Cleiser25
03-03-2014 08:35 AM
AFamilyAffair
12-31-2009 11:33 PM
Quick Reply: Eton viper mini 50 no power
