Lt80 drive belt
Old May 6, 2019 | 03:39 PM
Nick.m's Avatar
Default Lt80 drive belt
Evening just had my lads quad apart as the rear end locked up.... Always wondered why it only had one screw in the air box. Some how managed to get into the rear clutch after 2yrs of owning it..
How much slack should be in the belt?
Is it time for a new one ?
Old May 7, 2019 | 07:45 AM
LT80's Avatar
LT80 Expert
Belts wear forever. I highly doubt you need one.
As far as the slack, turn the rear clutch and get the belt up where it belongs.
Of course you know to service the clutchs while in there.
Old May 7, 2019 | 03:08 PM
Nick.m's Avatar
Will do cheers will have a search on the clutches only thing I know is about removing a couple front rollers
Old May 7, 2019 | 03:46 PM
LT80's Avatar
LT80 Expert
Front: You need to check the rollers for flat spots. If the grease got hard, there may be damage. Never know till in it. FYI: I only use a dab of grease and that's to hold the roller in place.
Rear: Make sure the bearings are good. Rough up the contact pads slightly to break the glaze. Squeeze the sheave together to make sure the sliding face travels easy.
Old May 8, 2019 | 01:07 PM
Nick.m's Avatar
Bugger time to replace them I think
Old May 8, 2019 | 08:44 PM
LT80's Avatar
LT80 Expert
That explains a lot eh. lol
You need everything.
Old May 9, 2019 | 06:44 AM
Nick.m's Avatar
Mmm....not checked the back end yet
Old May 16, 2019 | 06:35 AM
Nick.m's Avatar
And another question...
Picked up a complete variator.. Just went to fit it but noticed that the coller/spacer that slides through the middle is shorter than the original one
Do I need to fit the shorter one and fit an extra washer on the outside ?
Old May 16, 2019 | 08:23 AM
LT80's Avatar
LT80 Expert
You should just run the longer spacer.
But, yes, the short one needs the washer (it's a special washer).
Old May 16, 2019 | 01:47 PM
Nick.m's Avatar
Ok thanks thought I'd ask 1st
