Who lost a water pump impellar
Old Sep 5, 2003 | 02:08 AM
WISTECH's Avatar
Default Who lost a water pump impellar
I noticed Maz has metal water pump impellars for just a few bucks. Is there a problem with the plastic ones . Has anybody ever have one melt or did you damage it from overtightening. Im going to polish my frame and powdercoat my suspension in the break before the winter season and was thinking if I should get one of these installed while its down.
Old Sep 5, 2003 | 02:36 PM
cannondale27's Avatar
Cannondale had 3 different impellars I have seen the first two strip out they are made of a real soft plastic.The third is fibre reinforced and they havent failed but the only way to identify it is to look so if you have the cover off you might as well replace it with a aluminum one.I plan on it.
Old Sep 5, 2003 | 02:38 PM
WISTECH's Avatar
I guess for 5 bucks you cant go wrong.
Old Sep 5, 2003 | 04:08 PM
mxrookie's Avatar
I actually got all the parts to do the STUD UPDATE but have not pulled mine apart yet . I also an waiting on cooler weather to start my rebuild . to my knowledge as i have checked what i can in studs i have all tight still and have run 75-100 hrs from nasty trails to the lil saraha in Ok. so far so good ..... But i'll know more this Fall .
Old Sep 5, 2003 | 06:22 PM
Wistech I couldnt find the aluminum one on his site.All there is is the OEM(stock one).If you get ahold of him could you let me know when the aluminum ones are out and how much?Thanks
Old Sep 5, 2003 | 09:30 PM
WISTECH's Avatar
Oops My Bad , For some reason I thought the $5.00 impellar was made of metal but it is the latest factory fiber reinforced version that was developed to resist stripping or melting . I think it was that dam voice in my head. I thought I really did see an alloy one somewhere. Now I am worried that I may have the earlier version plastic one. I apologize for the mistake and I think I am going to order the the one Maz has if I cant find an alloy one.
Old Sep 5, 2003 | 09:40 PM
Maz did post somewhere that he was going to get a aluminum one made at Boysen.
Old Sep 5, 2003 | 10:04 PM
WISTECH's Avatar
Now I remember , It was Big Winky from Diamond racing who said he had an custom alloy one and he was trying to get them mass produced. I guess im just half insane. Maz Has the alloy valve covers to fix the corrosion problem with the magnesium one. I think I should make some myself out of aluminum if no one has any in case the plastic ones dont hold up. I get back to you when I get my s*** togetther.
ltrmc02
Aug 22, 2021 02:34 PM
Customer Service #1
May 15, 2020 08:46 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Canamaniac!
Sep 15, 2015 06:19 PM
