Big bore Dale's?
Old Oct 29, 2002 | 10:34 PM
mxmike's Avatar
Default Big bore Dale's?
Anyone think Cannondale is going to make a big bore thumper?
Old Oct 30, 2002 | 12:58 AM
AmericanBadass's Avatar
I heard something about a 700cc kit from a cannondale guy that seams to know about cannondale stuff way b4 most do. I would love it if they did. I think its a bolt on or some thing. maybe hes pulln my leg but i hope not. A EFI432 is fas now but a EFI700 damm!
Old Oct 30, 2002 | 09:50 AM
smitty911's Avatar
I don't thnk your ever going to get 700 out of the motor.
Trinity has mine apart and my be putting the 93mm piston and cyclinder in. There isn't alot of room to go to much bigger in bore. The sleeve starts getting pretty thin at that point. There may be room to have 1-2 mmm of stroke but this may cost you in RPM and be very expensive.
Smitty
Old Oct 30, 2002 | 12:01 PM
ZRWHAT's Avatar
Hey Smitty, why would you be downsizing from a 432cc to a 414cc? That's what you would have if you went with a 93mm piston? Just curious.
Old Oct 30, 2002 | 04:06 PM
Cdale1's Avatar
2004 cannondale will introduce the 450cc motor
Cdale1
Old Oct 30, 2002 | 11:42 PM
smitty911's Avatar
Sorry it's a 95mm piston. OPPS how big is it now.
Smitty
Old Oct 31, 2002 | 07:10 AM
ZRWHAT's Avatar
95mm is the stock bore, so 432cc.
Old Oct 31, 2002 | 09:04 AM
ZRWHAT's Avatar
If you went with a 97mm you would be at 451cc, but from what I have heard the wall on the cylinder is so thin that it isn't thought to be very reliable. Of course there is probably only a couple in the country like that, so I'm not sure if the reliability has really been tested either way. Unless of course Cannondale is designing a new cylinder for their next generation motor?
Old Oct 31, 2002 | 11:31 AM
smitty911's Avatar
Cut a little from the case, cut some more from here, from there, what the hell. The bigger bore is alot thinner I've seen it.
Not sure if I wanna do that just yet. If you didn't have to pull the motor to put the sleeve in.
Smitty
Old Oct 31, 2002 | 01:27 PM
ZRWHAT's Avatar
I've still got the motor for sale if you want one to experiment with!
