how can i wheelie with no clutch
Not that this is a good idea for the long term reliability but....if you hold the shift lever down when you shift into 1st... give it some throttle and release the shift lever, its like popping the clutch. Same thing if you do it from gear to gear. Real easy to get 2nd gear wheelies that way. Also real easy to loop out and hit your head real hard.
cdstang
08-31-2015 07:52 AM
