Installing chain on quad is this the tool I should buy?
Hi, I was wondering if this is the only tool i will need to remove my stock chain and install a new chain (D.I.D. 520 O-ring) on my 03 Z400 suzuki quad. If you could please go over the process of removing and installing the link thanks a lot
P.S here is the tool does this tool mushroom the rivet or do i have to do it another way?
http://alba.buyol.com/Item/PC005001.htm
toolhttp://www.motionpro.com/Docs/chaintools.html
Mini Chain Breaker & Mini Chain Press Tool.
The 08-0001 is for 420 to 630 chain. It will push the link pin completely through the link. The handle folds away for easy storage and the replaceable pin (08-0002) is heat treated for strength and wear resistance.
(Shown at left of photo) 08-0001: $27.10
Those tools do ok but when you get one be sure it is for an O ring chain.I have one for my Harley chains but it wont work on the Oring ATV chains.O them I use a Dremmil tool to grind the head off of the link and drive the pin out with a punch.Also when you put on a new master link if it is too thight to fit the pins run a Drimmel through it or use a rat tail file but be carful not to take too much off.
I heard people just use a punch to mushroom teh pin heads, is this true, i ahev also heard that this is the only tool i would need, if so how are they mushrooming the heads to keep the link on? I can use a c clamp to install the side plates.
Go to www.rockymountainatv.com and search for the following exactly as shown below:
Motion Pro Chain Breaker
You should get only (1) result and that's the exact tool I use. It'll work on O-ring and non. I just happen to use non-O-ring all the time an any of my dirt toys. I've used this tool for tons of chain work and it's always worked fine.
Frisky2050
04-09-2020 11:19 AM
