warrior rocker arm adj
There has to be some clearence between the rocker arm and the valve. How much depends on the cam you are running. You sig says .450 lift cam, with that one you need the gap to be .006" on both intake and exhaust. If you are not running that cam it will tell you the clearence on your timing card.
THANKS, this is actually another project that im trying to do all the mods myself.
i just installed a warrior cam and spring kit, and now when i press the start button it makes a very loud buzzing sound out of the white solenoid in the rear. All the lights work and my kill switch is in and everything seems fine but it wont start, ive tried charging the battery and checking the main fuse. any help? thanks
