maintanence on my warrior... need help ASAP! goin riding tomorrow... wanna get it maintanenced(by myself) b4 i go...
ok so what i wanan do is adjust valvee... clean plug( how do i get the wire off [img]i/expressions/face-icon-small-confused.gif[/img] ??? air filter is fine... also it shound sto b running rih.. which i was suggested to clean plug... also nething else i should check... plz post.. i really wanna get this thing workin good today... ALSO!!! all m frickin screws keep falling out this thing... out of the plastic... first the right side blots fell outta the grab bar now the hood bolts r comin out..
The plug wire just pulls straight off. I would check your bolts to make sure they are tight(use lock-tight on any that are giving you problems staying tight), also check tire air pressure, fluids, and I would lube your chain(possiably adjust chain slack) and maybe put some grease in your grease fittings
