2001 yamaha blaster
I plan on racing it this year i just bought it can anyone help me out with some mods to do to it to mkae it more stable and make it faster??
2001 yamaha blaster
My friend has one and his is pretty fast he has a fmf gold seris pipe, reeds, air vents, k&n, powerblade, larger carb, cdi and coil,cranshaft, and he removed the oil injection and e-brake.
2001 yamaha blaster
look into some new bars also..my buddy charlie has some TAG bars on his and he loves the fit. My new FLY bars are awesome to..so check into bars, bar risers, if u still have the stock tires get those off of there and put sum razors or holeshots w/rims on it as well. Some race cut fenders will give it an agressive look to:D[img]i/expressions/face-icon-small-cool.gif[/img]
2001 yamaha blaster
why would he remove the oil injection?? wouldent it cease up wen you run it. inform me plz. does it give more power.
2001 yamaha blaster
You remove the oil injection and run premixed gas.
2001 yamaha blaster
lighy
Originally posted by: Raptor350kid I plan on racing it this year i just bought it can anyone help me out with some mods to do to it to mkae it more stable and make it faster?? -A-arms -Shocks -Offset rims and 18 inch turf tamer tires -+2 extended swingarm -Porting -G3 reeds -Lightened flywheel -Killswitch, nerfbars, and number plates (All required for racing) -Oil injection blockoff and premix with amsoil That will cost around 3,500, good luck. |
2001 yamaha blaster
[quote]
Originally posted by: Raptor350kid I plan on racing it this year i just bought it can anyone help me out with some mods to do to it to mkae it more stable and make it faster??[ get a,pipe,extended swingarm/axle/a arms,some new suspension, some itp holeshot tires on itp .190's rims, jet kit, delta v-force reeds, k/n air filter, take of ur airbox cover, get a hot rod crank and connecting rod,wiseco piston n rings, n some kam 2 race fuel n ur good 2 go |
2001 yamaha blaster
What kinda racin are you plannin to do? Track or Drag? I have a 03 blaster and I am setting it up for draging 300 feet. Look the First thing is get a good pipe. Depending on what you want out of your motor. If you want to go big bore I would get a CPI in frame drag pipe. But I kept mine stock dispalcement so I went with a Toomey, and they are great for ported motors. But they are not for big bore kits they don't move enough exaust. then I would buy a lowerin kitand extened swing arm. then its all about money and what you want.Like I said I got a toomey, I had my jug ported, head rechambered,carb rifled, flywheel lightened,lowering kit. and I'm waiting for my swing arm. let me tell you Those mods. if done right will make you fly like a bat out ah hell.
