clutch cost?
The parts would most likely run about $120 complete. To have a shop do it it would likely again cost double that with labor.
R&R'ing a clutch isn't that difficult, from the technical standpoint and relative to other systems on your ride.
Buy a manual, you should have anyways, and look over the procedure for clutch replacement. See if you think you have the tools and ability to complete it and have at it.
Some general notes. Always make sure that the engine has been washed before cracking into it, for whatever, even changing an air filter element. The less "debris" there may be the less chance that it can wind up in your engine.
Good luck!!!
Good luck!!!
