High low issue 2006 Arctic Cat 700 EFI
Hi everyone,
i am having a issue with engine bogging dawn and sputtering when I am driving in high gear. Doesn't let me go over 15km. When driving in low it operates fine. Nuetrul also works fine. Please help. Thanks |
Here's a few things to check, the Diodes are both pointing the same way, one didn't get reversed, accidentally? Check fuel pressure, check all wires going to throttle body for chafe. Any codes? Wish I was more helpful, I have a 2014 700 TRV, but it's been trouble free so far.
does anything change when you push the reverse over ride button? Sounds like its coming on when it should not..
Hi everyone, when I push the reverse override while driving in high. It allows the high range to climb in speed to about 75% of limit, then starts sputering. Then I let off the reverse override and hit the throddle. It boogs down and it won't let me have any throddle till it reaches lower speed such as 15km per hr. I hope all this makes sense. Thanks for everyone's help on this.
Go over to the arctic cat forums and do a search. Been a few reports over their of the same issue. Can't remember what the fix was of the top of my head...
don't like sending people to other forums but it's brand specific and the issue is their with the fix |
