300EX questions..
I have two questions concerning a 300ex.. First.. Electrical.. When I pull my clutch in, When in neutral, and shift into first. My neutral light stays on, then I slowly release the clutch untill it clicks, then the light goes out. Then if I pull the clutch back in, the neutral light comes back on. What do you think ??
Second.. Motor.. While in neutral and engine running, everything sounds good. Then I pull the clutch in, still good, shift into first is where the problem is. I here a weird humming sorta noise. Like something turning without any lubrication. Checked oil, its fine. What do you think of that ?? I am leaning toward the clutch.. But what in the clutch ??
I hope someone can help with these problems.. I'll have to listen more closely to figure the second problem and get you a better feeling for what is going on..
Thanks in advance.....
Jason
Jason
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
tank10rnk
Aug 10, 2015 08:19 PM
