Just assembled motor, it started, ran, and now won't????
I just reassembled my zilla motor, started it with a new plug, and then it died. I try to start it now all it seems to do is backfire, no starting. Any input it appriciated. And also, when the crank starts to go, does it vibrate like he11? This thing is vibrating and I checked all the dots on the gears and there lined up fine.
get a new plug, check your timing,some times people don't use locktie and they will come loose, make sure that your exhaust valve is opening,you will be able to see it,if the engine mounts are loose, it will vibrate, if that dont work pm me.
Run a compresion check and if it has compresion check your spark and fuel.If no comp pull your carb and reed valve and check your piston it could have broke causing your viberation.
check your reeds, make sure they are shutting
my friend had a tri-moto built and he started it ran and drove then it woulnt start, it turened out to be the timing or somthin
when i did my banshee it did that and it was the jetting
Originally posted by: homeslice when i did my banshee it did that and it was the jetting |
The firing problem is probably electrical. Check to see if you have spark. if you dont go down the line and see what component is failing. If your worried about a loose crank be smart and take the cylinder off. Check the up and down movement on the big end of the rod. You should have almost none. Next check your side to side, you shouldnt have much, but it should wiggle a little. Its always smart not to put a crank to chance!
| All times are GMT -5. The time now is 09:39 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
