2013 850xp
  #21
Old 02-15-2014, 08:48 PM
Tps is just for the correct position at a certain voltage,really no different than the other tps sensors other than this one has a pig tail. Same thin wiring leading from it to the main harness as all the others. The tmap just senses temp/air pressure,sends it to the ecu(ecm) for correct fuel mixture to injectors. This is the same sensor that's used on the 500 efi machines and the same crappy thin wiring also. Could be a sensor problem,but we had wiring problem on the 2010 and 2011 models when I retired. Don't know if Polaris has learned anything since then? Item #8 and 25.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Plus OTB is starting to have harness kits for the 850xp also.
Jeff Roper
02-01-2022 11:48 AM
Alex G.
09-19-2015 06:34 PM
Canamaniac!
09-15-2015 06:19 PM
Randy Lee Frye Sr.
09-09-2015 02:30 PM
David Diaz
09-08-2015 04:44 PM
Quick Reply: 2013 850xp
