01 Trailblazer handlebar control compatibility
Old 02-28-2015, 07:59 AM
parrotheadad@gmail.com's Avatar
Smile 01 Trailblazer handlebar control compatibility
Can a handlebar switch control from a 2002 be used on my 2001. They look very similar but have different part numbers. Do they use the same wiring harness ?
Old 02-28-2015, 09:26 AM
No need to post twice in the regular forums and here also!
Old 03-01-2015, 02:52 PM
Post
The 2001 has the same combo kill / start switch where you lift the switch to start it. I guess what matters then is if the wiring harness assignments are the same.
Old 03-01-2015, 02:59 PM
Then possible it might work as a couple years did have the push up switch,can't remember all the models. And yes,possible wiring can be a little different or even wiring in the connector pins could be switched around. That's why I say always get the correct one for your model,then you won't have to worry or possibly have problems.
salixair
11-03-2015 08:25 AM
MikeyBoyesq
09-22-2015 10:02 AM
MrTrashMan2U
1) Engine problems..
09-09-2015 11:11 AM
chewy78
09-08-2015 10:37 AM
Jason Campbell
09-07-2015 02:25 PM
Quick Reply: 01 Trailblazer handlebar control compatibility
