scrambler 50 Starter relay
Old Feb 1, 2013 | 06:05 AM
Glad you found the problem.Ignition switch wiring wasn't soldered too well at the bottom of the switches either on these machines.I've found this to happen also. The air/fuel mixture screw normally sets between 1 to 1 3/8 turns out from a lightly seated position. You'll just have to play with it. Make sure the air cleaner is ok and the carb is clean,I'd pull the jets and clean to make sure,PLUS there is a small vent that has to be open on the carb bowl.Compressed air or carb spray may be needed. Good luck,hope the grand kids like the atv. OPT
ghost civic
Jan 15, 2020 07:43 AM
sweaver
11
Aug 18, 2015 03:47 PM
raceware
Jul 30, 2015 06:59 AM
Bratman2
Jul 23, 2015 12:36 PM
cornermike
Jul 8, 2015 11:44 PM
